Changing inactive records
  • 1.  Changing inactive records
    Posted Sep 21, 2020 01:56 AM
    Hello
    In Dynamics CRM 2016 records of all entities can be set to inactive. Once inactive, the are not editable anymore.
    However, is it possible to update them programmatically, for example by code, 3rd party tools like Simego, XRM Toolbox etc? Is there something special I have to keep in mind?
    Thanks a lot.
    Regards
    Heinz
  • 2.  RE: Changing inactive records
    Posted 30 days ago
    With a few exceptions, yes inactive records can be updated programmatically. In XrmToolBox you could use Bulk Data Updater or SQL 4 CDS. You could also look at tools such as KingswaySoft for more automation.
    Mark Carrington
    Chief Technologist
    Data8
    Chester
  • 3.  RE: Changing inactive records
    Posted 30 days ago
    Inactive records may also be edited in mass using the Export/Import feature.
    Hugh Konigsmark
    Global CRM/CPQ Director
    Bray International, Inc.
    Houston TX
  • 4.  RE: Changing inactive records
    Posted 30 days ago
    You can also use a Dynamics workflow for each entity to update inactive records.  If you are updating a lot of records, I believe there is a utility in XRMToolBox that will run workflows on large batches of records.
    Terry Letkeman
    Bespoke Technology Services
    Winnipeg
  • 5.  RE: Changing inactive records
    Posted 29 days ago
    If it is just single record that you need to update we use the Level Up Chrome extension. It is awesome. Go God mode and you can update anything you need to whether active or inactive.
    Good luck
    Anthony Roth
    Director of Business Systems
    Sacramento CA
  • 6.  RE: Changing inactive records
    True story! But goodness God Mode can be SCARY if it's in the wrong hands!
    Evil laugh |  MINE! IT'S ALL MINE!!
MWAHAHAHA | image tagged in evil laugh | made w/ Imgflip meme maker
    Heidi Neuhauser
    Director, CRM Projects
    Reenhanced
    Green Lane PA
  • 7.  RE: Changing inactive records
    Right!! I rarely show this to anyone other than my team. Really makes you think through whether or not we need field level security. Editable Grids seem to give similar access to fields we as admins are protecting due to read only or hiding.
    Anthony Roth
    Sacramento CA
  • 8.  RE: Changing inactive records
    Edited by Heinz Arnold 16 days ago
    Hello
    Thanks a lot for all your answers. Good for now, I used Simego to update the records. It worked without problems.
    Have a nice day.
    Heinz
