  • 1.  How to open mbox file?
    Posted Dec 07, 2021 04:08 AM
    Edited by Shaon Matt Dec 07, 2021 04:11 AM
    Want to know how to open MBOX file? If yes, then I believe you have searched some questions to get here. But still need a method to open.mbox file without installation and configuration of email client.
    Don't worry I have freeware MBOX Viewer tool which supports almost all MBOX-based email clients and provides clear preview to user even with large mailboxes. The software specifications can be easily met by every Windows system, also you can operate it without any technicalities.
    This is my personal suggestion if you want MBOX Viewer. Download and install MailsDaddy Free MBOX Viewer Tool and open .mbox file in just a few easy clicks. I know your search query "How to open mbox file?" Usually shows you a lot of searches but trust me only a few of them are successful. So if you ever want to watch MBOX file then try this freeware utility.
    Steps to use MBOX Viewer
    Download MBOX File Viewer Tool and run it on any Windows OS operating system.
    Run the application and click the Add File button
    Select a method to load the MBOX file into the software.
    Click Next to view/open MBOX file on the right side of the display window.
    It is developed professionally for the user so that you can go ahead and import MBOX to Outlook, Office 365, Live Exchange, EML, MSG etc with pro version. For any convenience and assistance, please contact MailDaddy Support Team.
    Reference
    MBOX viewer
    Open .mbox file
  • 2.  RE: How to open mbox file?
    Posted Dec 14, 2021 02:16 AM
    In case you are searching for the solution of How to open MBOX files then there are various methods to do this. If you do not have any MBOX-supported email clients then you can convert MBOX files to PST to open them in Outlook. This way you can view the data of your MBOX files in MS Outlook. You can perform this action by using the manual or a professional approach. To accomplish this task manually, you can refer to this informative article that will help you to convert MBOX files to Outlook. Otherwise, there is a free tool available that allows you to view the MBOX file data without any email client.
    You can try the MCT MBOX file viewer software to view the data of the MBOX files. However, there are some limitations like you are not able to share that file with others. You can only read and view the file data. Therefore, many users want to convert the MBOX files into other file formats like PST to access and share them in Outlook.
    Mike Foster
    Software Developer
    San Jose CA-95134, USA
