user cannot open dynamics 365 CE from outlook new add-in
  • 1.  user cannot open dynamics 365 CE from outlook new add-in
    Posted Oct 04, 2019 10:20 AM
    Edited by giovanni manunta Oct 04, 2019 10:27 AM
    only one of my user is still experiencing this error
    I cannot connect to dynamics 365 from outlook using the new addin
    this is the error
    Activiteit-id: 9dc1e579-8e1c-47e6-9e5d-01d2769372f0 datum: Fri, 04 Oct 2019 13:04:02 GMT fout: CRMProvider.GetAppId XMLHTTPRequest failed tracering: Error: CRMProvider.GetAppId XMLHTTPRequest failed at Anonymous function (https://xxx.crm4.dynamics.com/crmmailapp/scripts/shim.js?v=1.2.425.1:1:112328) at r (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:18:9351) at i.prototype._settlePromiseFromHandler (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:17:14559) at i.prototype._settlePromise (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:17:15364) at i.prototype._settlePromise0 (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:17:16065) at i.prototype._settlePromises (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:17:17284) at r.prototype._drainQueue (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:16:3131) at r.prototype._drainQueues (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:16:3189) at drainQueues (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:16:1313) at Anonymous function (https://xxx.crm4.dynamics.com/uclient/scripts/bluebird.js:17:31140)
    do you have some idea what is it and how to solve it
    Met vriendelijke groeten,
    giovanni manunta
  • 2.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Oct 04, 2019 10:39 AM
    @giovanni manunta - Does the user have the "Dynamics 365 App for Outlook User" security role? Also, in their primary Security Role(s), check the Business Management tab.
    ACE Microtechnology
  • 3.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Oct 04, 2019 10:57 AM
    yes he has correct sec roles&privileges
    giovanni manunta
    Georg Fischer
    cernusco sul naviglio
  • 4.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 06, 2019 05:18 AM
    Hi Giovanni,
    I am currently facing the exact same issue. Would you mind posting your solution if you found one, so that others can learn from that in the future?
    thanks,
    Rogier Vriezen
    Functional Consultant
    Amsterdam, Netherlands
  • 5.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 06, 2019 05:32 AM
    Edited by giovanni manunta Nov 06, 2019 05:42 AM
    Okay, thanks for your question
    We fixed in this way
    1)     We open a ticket to Microsoft
    a.      After 2 or three meetings we discovered together that that user must to add these trusted sites
                                                        i.     *.dynamics.com
                                                       ii.     *.microsoftonline.com
                                                      iii.     https://login.windows.net
    b.      Then we cleaned up the Internet Explorer Cache(IE not chrome) and we removed the Internet Temporary file from IE (again IE, not CHROME)
    This worked for us.
    Another useful link Microsoft Provided:
    https://support.microsoft.com/en-sg/help/4035750/something-went-wrong-during-sign-in-error-using-dynamics-365-app-for-o
    Let me know
  • 6.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 07, 2019 09:57 AM
    Glad you got a resolution. The app is built on IE tech. We've had similar, and even if user never uses IE, the solution almost always involves clearing their IE cache.
    Ryan Perry
    Auric Solar
  • 7.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 07, 2019 10:33 AM
    Yes at the end we fixed , I am sorry for the delay in getting back to all of you.
  • 8.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 19, 2019 02:40 PM
    I too have an issue (newly) with loading Dynamics from within the outlook client app. All works fine on the browser version of outlook, but not on the client version. I have deleted the caches of IE, edge, Outlook multiple times. I have also done all the steps suggested in this thread. No luck. this is the error message i am consistently seeing:
    Activity ID: ed0f4422-6fff-4a49-9226-1192308d32a6 Date: Tue, 19 Nov 2019 19:32:07 GMT Error: CRMProvider.GetAppId XMLHTTPRequest failed Trace: Error: CRMProvider.GetAppId XMLHTTPRequest failed at Anonymous function (https://companyx.crm.dynamics.com/crmmailapp/scripts/shim.js?v=1.2.448.1:1:110012) at r (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:18:9351) at i.prototype._settlePromiseFromHandler (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:17:14559) at i.prototype._settlePromise (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:17:15364) at i.prototype._settlePromise0 (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:17:16065) at i.prototype._settlePromises (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:17:17284) at r.prototype._drainQueue (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:16:3131) at r.prototype._drainQueues (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:16:3189) at drainQueues (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:16:1313) at Anonymous function (https://companyx.crm.dynamics.com/uclient/scripts/bluebird.js:17:31140)
    Stu Fisher
    Bluewave Communications
  • 9.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 19, 2019 04:02 PM
    Edited by giovanni manunta Nov 20, 2019 03:25 AM
    Can you open a ticket to Microsoft Support ?
    They help us a lot
  • 10.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 19, 2019 04:07 PM
    I have already donee that as well -
    Stu Fisher
  • 11.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 20, 2019 01:52 AM
    Edited by giovanni manunta Nov 20, 2019 03:23 AM
    Have you deleted the Internet Explorer Temporary Files ?
  • 12.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 20, 2019 02:51 AM
    I have seen that happening for one of our users too. In his case, he had installed a new Beta version of Edge. After uninstalling that beta browser, his app worked again.
    let us know if that helped.
    Rogier Vriezen
  • 13.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 20, 2019 03:24 AM
    Hello Rozier,
    Did you install the Bet of IE , then after the issue is fixed did you uninstall it ?
  • 14.  RE: user cannot open dynamics 365 CE from outlook new add-in
    Posted Nov 20, 2019 04:08 AM
    No, one of my users decided to install it. Then the issue started happening weeks later.
    After we uninstalled the BETA Edge, the issue was solved.
    You might be facing the same issue with a completely different cause, but it's worth trying IF you have a beta version of Edge installed.
    Rogier Vriezen
