Sunil - with several workflows failing, a change to a security role could be a likely culprit. If it is set to run as the owner, has the workflow owner changed or the security role for that owner changed? If it is set to run as the user who triggered the workflow, has that user's security role changed? Also, what is the scope of the workflow? If it is set to user, you might need to set it to organization.
I am generally able to spot why a workflow failed by looking at the details in the error and which step failed but when that isn't really clear, I take one instance of the failed workflow and look at the record (or records) that it touches and follow the steps the workflow takes navigating through the records. Sometimes that allows you to see where a step isn't working because some field or value isn't what you expect. We have integrations pushing data into our environment, so sometimes a change to an integration might push data in differently or be missing a value needed by my workflow.
Sent: Jul 30, 2019 02:38 PM
Subject: Workflows started failing with Invalid Argument error
We have a situation with many different workflows failing since past 2-3 days with the error message (Invalid Argument)
In the details section I can see the error message: Expected Non-empty string Parameter name: settingName
Not sure what changed suddenly. Anyone has any idea?
Sunil Raheja
Aha Apps
Glen Allen VA
