Updating Status Reason with Workflow
  • 1.  Updating Status Reason with Workflow
    Posted Sep 17, 2019 09:04 AM
    Hi All,
    I seem to be unable to update the status reason field using workflow (I have been able to do this with flow, but the client I am working with is hesitant to use flow). Does anyone know why? I am trying to set a record to inactive with a specific status reason.
    Appreciate all thoughts!
    Emma,
    Emma D'Arcy
    MCSE: Business Applications
    Pre-Sales Consultant
    ClickDimensions
  • 2.  RE: Updating Status Reason with Workflow
    Posted Sep 17, 2019 09:41 AM
    I believe when you use the Change Status step in a workflow, you are actually setting the combination of Status and Status Reason.  I looked at an entity in my system which has multiple status reasons for active and inactive and I see bold Active and Inactive with the unbolded status reasons below each.
  • 3.  RE: Updating Status Reason with Workflow
    Posted Sep 17, 2019 09:43 AM
    Yep. That's the one. I haven't had to build a WF in a while and this is exactly what I need! Thank you!
    Emma D'Arcy
    ClickDimensions
