Deleting Audit Records
  • 1.  Deleting Audit Records
    Posted May 31, 2019 12:36 PM
    I have recently disabled auditing on a lot of fields and i now need to delete old records (selectively). Few questions.
    1. Can i delete audit records from specific entities? We dont really want to delete by date.  I googled and it seems like you cant but that maybe there is some new functionality with 9.0?
    2. I feel really silly because I have been told that there are audit logs and audit records in a table.  Are they different? I cant really seem to figure out how they are different.
    thanks in advance for your help!  Laura
  • 2.  RE: Deleting Audit Records
    Posted Jun 02, 2019 01:09 PM
    Nope, you cannot pick and choose :(
    (I just cleaned out eight years of audit logs for a customer yesterday!)
    Julie Yack
    Colorado Technology Consultants, Inc.
    Palmer Lake CO
  • 3.  RE: Deleting Audit Records
    Posted Jun 03, 2019 05:30 AM
    Edited by Mark Aston Jun 03, 2019 05:31 AM
    Hi @Laura Mortick, Julie is correct.  You can't delete the audit logs for specific entities.  You are tied down to deleting an entire quarters log for all entities that have auditing enabled.  You can also only select the oldest log.  If you try to delete any other logs, you'll get the following error message...
    We went through the same exercise as yourself last year and were able to massively reduce the size of our quarterly audit log 's.  We also decided to delete our audit log's up to the end up 2017 to free up some storage.  I'm not aware that there is any functionality in v9 to delete specific entities but if you do find it, please let us all know.
    As for your second question, i'm not sure what audit records are.  It could be referencing the Audit Summary View, which allows you to see certain actions (e.g. create, update, delete) for an individual record.  There is an option to Delete Change History which i've never used but it only allows you to select one row at a time.
    Hope this helps.
  • 4.  RE: Deleting Audit Records
    Posted Jun 03, 2019 09:46 AM
    Thank you @Mark Aston and @Julie Yack - I appreciate your reply.  That is too bad that we cant query on the audit records using advanced find and set up some bulk deletes using specific criteria.  I just recently learned that you can view the audit record on the entity that is being audited.  In that case, I assume the only field that will show are the specific fields I am auditing?​​
    I guess i need to bite the bullet and delete the old audit records. Going forward there will be a lot fewer since we turned off auditing on many entities and fields.
    Thanks again!  Laura
  • 5.  RE: Deleting Audit Records
    Posted Jun 03, 2019 09:51 AM
    No problem @Laura Mortick.  You are correct, when you are viewing the Audit History for a record, you'll only see the history for the fields that have auditing enabled.
    I think its worth biting the bullet and deleting the old audit records, assuming the users are happy with this and aware you are doing this.
  • 6.  RE: Deleting Audit Records
    Posted Jun 04, 2019 03:21 AM
    It's worth pointing out here that the new Capacity limits for logs is 2Gb.
    https://docs.microsoft.com/en-gb/power-platform/admin/capacity-storage
    You can buy more - see limits and pricing table capture from a PDF available on the above page.
  • 7.  RE: Deleting Audit Records
    Posted Jun 04, 2019 06:11 AM
    Hi Laura,
    While you can't pick and choose where you delete audit records from; you can raise a ticket with Microsoft and get them to do it for you.
    We did this just over a year ago, tested it in a sandbox copy of prod and then they did it for us on the agreed date/time.
    Just another option for you.
    Sharon
    Sharon Fish
    Beyond Bank Australia
  • 8.  RE: Deleting Audit Records
    Posted Jun 04, 2019 06:17 AM
    Hi @Sharon Fish, thats really useful to know, thanks for sharing with us.
  • 9.  RE: Deleting Audit Records
    Posted Jun 04, 2019 08:10 AM
    Thank you @Sharon Fish!  I thought i read somewhere that it could be done. We will definitely open a ticket with Microsoft! Not sure why they dont allow us to do this ourselves!​ Thanks again! Laura
  • 10.  RE: Deleting Audit Records
    Hello all,
    Found this post searching the topic and thought I'd add a question to it.   We deleted a bunch of audit logs from D365 but now the capacity in Power Platform Admin center has shot up, will that go down eventually in a couple days?
    Thank you
    Tim Dailey
    Starkey Hearing Technologies
    New Hope MN
