CRM Form Issues with Chrome Update 72
  • 1.  CRM Form Issues with Chrome Update 72
    Posted Jan 30, 2019 11:27 AM
    Has anyone noticed issues with the Chrome 72 updating cutting off the top of CRM forms (unscrollable area)?  It works fine for those who have not received the latest Chrome update and works fine using IE.  I'm running CRM version 1710 (9.1.0.1471) online.
    screen shot 1This is what it should look like:
    screen shot 2
    Jeff Henry
    Application Manager
    XTRA Lease
    Saint Louis MO
  • 2.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 30, 2019 11:40 AM
    Are you experiencing this in other browsers? Have you experienced this issue in the Unified Interface?
  • 3.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 30, 2019 11:53 AM
    Hi Aaron,
    We are not using the unified interface yet.  All other browsers and versions of Chrome work fine.  Only seeing this issue with Chrome 72.0.3626.81 which was installed this morning and seems to be the latest version.  (I tried to uninstall it and go get the latest version of Chrome and wound up with the same version.)
    Jeff
    Jeff Henry
    Application Manager
    XTRA Lease
    Saint Louis MO
  • 4.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 30, 2019 12:04 PM
    @Jeff Henry - I just verified my Chrome version and it's the same as yours. I then checked my CRM system and I am seeing the Header section just fine without any issue.
    Does your Chrome have any addins/extensions? If so, I would suggest remove all extensions, test it out, then add the extensions back one-by-one until you find the culprit. ​
  • 5.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 02:48 AM
    Jeff - I presume you tried clearing your cache?
    I just updated to  Version 72.0.3626.81 (Official Build) (64-bit) and I'm not seeing anything amiss so far.
  • 6.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 04:03 AM
    Arghh - I spoke too soon re Chrome 72
    I'm seeing a similar form issue with the top of the form truncated. Main impact is being unable to access form menu.
    I'm also seeing a weird solution export issue - solution zips are being exported with '' around them in the actual filename, e.g. 'solution.zip' instead of solution.zip.
    Edge seems to be working fine though.
  • 7.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 08:25 AM
    We've had some users report this problem in Chrome recently as well and I need to confirm what browser version they're on. After reading this thread, I suspect it's 72. We are on Service Update 14 of Customer Engagement. It's does seem to be the header section of forms that won't render correctly. I have Chrome version 71 and it works as expected in that version.
    Andy Arndt
    Minitab, Inc.
    State College PA
  • 8.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 08:26 AM
    ​We have the same issue, affecting all users. IE works OK, though not in other respects, so users are advised not to use it :(
    I've tried clearing the cache and disabling extensions, this has no effect - does anyone have any other suggestions?
    John Upton
    Paragon Bank
  • 9.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 09:47 AM
    Chrome 71 was working fine. I just updated and I have the same problem with 72.
    Nelson Johnson
    Solution Architect
    BroadPoint Technologies, LLC
    Bethesda MD
  • 10.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 10:09 AM
    Edited by Julie Reynolds Jan 31, 2019 10:10 AM
    I've seen something similar happening with our header on occasion. I believe it was with our custom logo. I found that if I zoomed out with Ctrl- then it went away.
    Julie Reynolds
    Brotherhood Mutual Insurance
    Fort Wayne IN
  • 11.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 10:06 AM
    I am not noticing any header issues, but noticed my footer has disappeared all together after updating to Chrome 72.
    Jefferson Daniel
    Sun Valley Solar Solutions
  • 12.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 11:45 AM
    ​'Ctrl -' doesn't fix it for me, but pressing F11 for full screen does - press it again to go back to non-full screen and he title bar (or whatever you call it) remains. Only problem is that you need to do this on each page.
    John Upton
    Paragon Bank
  • 13.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 03:33 PM
    I noticed within my Microsoft 365 Admin Center a service issue message for Dynamics 365. This is very specific as it states "Form headers not rendering in Google Chrome".
    Here are the details in the message:
    Title: Form headers not rendering in Google Chrome
    User Impact: Users may not be able to view form headers when using Google Chrome version 72.
    More Info: As a workaround, users can properly view forms using other internet browsers or older versions of Google Chrome.
    Current Status: Our initial investigation determined that forms may not display headers properly when users are viewing in the latest version of Google Chrome (version 72). We are currently investigating telemetry to determine the next steps.
    Incident Start Time: Wednesday, January 30, 2019, 10:52 PM UTC Next Update: Thursday, January 31, 2019, 9:30 PM UTC
  • 14.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 03:41 PM
    ​Thanks for the info @Aaron Back, MCSE​! I thought our impact was limited to our logo, but later in the day we discovered we are impacted as everyone else is. Ctrl - does help a little bit, but it doesn't fix it like the logo issue. Hopefully it gets resolved quickly.
    Julie Reynolds
    Fort Wayne IN
  • 15.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 04:59 PM
    We're experiencing this problem in one of our instances and it turns out that we added some code to reduce the spacing in v9, have any of you guys done the same thing? We believe the spacing is enhancing the problem.
    We have another instance without the spacing fix in V9 where the problem is not as bad.
    This is the link for the spacing fix we did:
    Reduce Dynamics 365 v9 Field Spacing
    GitHub remove preview
    Reduce Dynamics 365 v9 Field Spacing. GitHub Gist: instantly share code, notes, and snippets.
    View this on GitHub >
    Thank you
    Antonio Cordero
    Sr. Technical Analyst
    Defenders
    Indianapolis IN
  • 16.  RE: CRM Form Issues with Chrome Update 72
    Posted Jan 31, 2019 05:25 PM
    Hi Antonio,
    Thanks for the feedback.  I got very excited because we did in fact add that javascript to reduce spacing.
    And I did read the disclaimer that it
    is not supported so I kind of expect to see issues related to this at some point.
    Unfortunately, when I took it out it didn't seem to help the form header problem.
    As you can see, the extra form spacing is back, but the header still does not appear.
    screenshot1
    Jeff Henry
    Application Manager
    XTRA Lease
    Saint Louis MO
  • 17.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 01, 2019 02:53 AM
    Thanks @Aaron Back, MCSE
    Got to love this workaround.More Info: As a workaround, users can properly view forms using other internet browsers or older versions of Google Chrome.
  • 18.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 04, 2019 06:15 AM
    I raised it with MS Support and got the following response on Friday (just picked it up today):
    I've read the verbatim and screenshots provided and I understand that your users have impaired vision after a Chrome Update. After a research within our database I've confirmed that this issue was reported initially yesterday.
    The good news here are that our code fix team did their best and utilized a hotfix that will be pushed within all regions, automatically, by the end of next week - 08/02/2019.
    However, logging into day, I find that the issues is actually already fixed, one way or another. Other users also confirm this.
    John Upton
    Paragon Bank
  • 19.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 04, 2019 09:18 AM
    My CRM online was updated over the weekend to 9.1.0.1669 and now the issue with the form header seems to be resolved.
    Jeff Henry
    Application Manager
    XTRA Lease
    Saint Louis MO
  • 20.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 04, 2019 01:59 PM
    Hi Jeff,
    Can I ask a silly question please?
    How can you tell it was updated over the weekend?
    Kevin
    Kevin Harrington
    CRM Product Manager
    Universtiy College Cork
  • 21.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 04, 2019 02:27 PM
    I can tell my client's instances were updated because they had 9.1.0.1471 last week and now they have  9.1.0.1669
    Nelson Johnson
    Solution Architect
    Bethesda MD
  • 22.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 05, 2019 11:29 AM
    Hi Kevin,
    Sorry I missed your question yesterday, but I would agree with Nelson.  I've gotten in the habit of checking the CRM version every morning because I never know when it will be updated.  I usually take a screenshot of the version info when it changes and paste into a Word document with the date to try to keep track.  I see messages on the admin Message Center that say we will be updated to version x on a certain date and it may or may not happen.  Then sometimes we get an update that was never mentioned in any message in the Message Center.
    If your question was more of a how/where can we view some type of update history with version number and date installed, I would LOVE to know the answer to that question.  Maybe we should start a new thread.
    Jeff
    Jeff Henry
    Application Manager
    XTRA Lease
    Saint Louis MO
  • 23.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 08, 2019 04:52 PM
    Thanks Jeff and Nelson,
    I would also love to have some place where we could see all the updates deployed to our environments along with a link to the detail of what was included in each. In fact why not also include updates that are scheduled as well, that would be useful too. I will take your advice and start tracking the version number though - good tip!
    Apologies for the delay in coming back to this thread.
    Kevin
    Kevin Harrington
    CRM Product Manager
  • 24.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 08, 2019 05:57 PM
    Kevin,
    I agree it would be nice to have one place to see everything related to updates and our specific instances, but it seems to be revving fast these days and rather than us getting notifications, we have to go looking for information. I try to log in frequently to the message center to see messages about scheduled updates. If you're not already aware of this site, here's a link to what is included in each minor release (Service Updates): https://support.microsoft.com/en-us/help/2925359/microsoft-dynamics-crm-online-releases
    Andy Arndt
    Minitab, Inc.
    State College PA
  • 25.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 08, 2019 06:04 PM
    Thank Andy,
    I have bookmarked this!
    Just asking, do you know off hand when we might be getting a sandbox for the major update in April?
    Kevin
    Kevin Harrington
    CRM Product Manager
  • 26.  RE: CRM Form Issues with Chrome Update 72
    Posted Feb 09, 2019 09:57 AM
    I haven't seen any information about when the April update will start showing up in the admin portal for scheduling the update. I think the general availability is April 5th. I checked the following:
    https://docs.microsoft.com/en-us/business-applications-release-notes/April19/dynamics365-sales/
    https://dynamics.microsoft.com/en-us/roadmap/sales/
    Andy Arndt
    Minitab, Inc.
    State College PA
