Solution file problem with Chrome 72
  • 1.  Solution file problem with Chrome 72
    I am working with Chrome 72 and D365 Version 1710 (9.1.0.1471) online
    I just created a solution this morning and Chrome is surrounding the solution name with quotes! I tried it again with Firefox and had no problems:
    I RECOMMEND that you DO NOT CHECK the version of Chrome you are running because that will trigger an update. Chrome 72 seems to have multiple issues.
    Nelson Johnson
    Solution Architect
    BroadPoint Technologies, LLC
    Bethesda MD
  • 2.  RE: Solution file problem with Chrome 72
    Hi @Nelson Johnson - Yep I saw the same thing yesterday and reported it in the other Chrome 72 thread.
    It's a way more esoteric error than the one re form headers are missing!
    Did you report it to MS? The 'CR172792 - Form headers not rendering in Google Chrome' advisory in service health does not mention this issue.
  • 3.  RE: Solution file problem with Chrome 72
    We are facing the same problem. Appeared with the new Chrome version.
    Yvan Leclerc
  • 4.  RE: Solution file problem with Chrome 72
    We are facing the same issue with downloading attachments on records.
    Chrome will rename the file with 'filename.format', which caused the format issue.
    Any potential solution here? I had suggested users to use Edge for now.
    Hao Qin
    CRM Manager
    Winslow Technology Group LLC
    MA
  • 5.  RE: Solution file problem with Chrome 72
    Posted 6 days ago
    Hi all, just a heads-up that this appears to be an issue with Chromium and it has been verified and assigned for resolution:
    https://bugs.chromium.org/p/chromium/issues/detail?id=927366
    Mike Cutlip
    RAMCO
    www.RAMCOAMS.com
    Durham, NC
  • 6.  RE: Solution file problem with Chrome 72
    Posted 5 days ago
    The same issue exists for data exports (e.g. "Export to Excel").
    The simple workaround is to edit the file name in File Explorer and remove the quotes.
    I am glad to see that it has already been submitted in a Chromium bug report.
    Jesse Ruppell
    BI Development Process Manager
    Microsemi Corporation
    Kanata, ON, Canada
    Dynamics 365 CRM 2.1 On-Premises
  • 7.  RE: Solution file problem with Chrome 72
    Posted 5 days ago
    Just to give a quick update: we experienced the same issue last week, as we checked this morning, the bug disappeared. It seems it has been resolved.
    Hao Qin
    CRM Manager
    MA
  • 8.  RE: Solution file problem with Chrome 72
    Posted 4 days ago
    Although this may have been resolved for D365 CRM Online users, this may remain an issue for on-premise users indefinitely. Per the Chromium bug report, Chrome is not planned to be patched to resolve this, at least for now, and who knows when or if Microsoft will provide a hotfix. Therefore the simple solution I implemented for our on-prem systems (and it works like a charm) is the RewriteRule suggestion in comment 50 of the Chromium bug report: https://bugs.chromium.org/p/chromium/issues/detail?id=927366#c50
    FYI, in case it helps anyone, in my case I added the RewriteRule through the the ISS graphical interface on each of my web servers, and found that I had to remove the """ in the RewriteRule Value string - I used "{R:1}{R:3}{R:4}" instead of "{R:1}"{R:3}"{R:4}".
    Jesse Ruppell
    Kanata, ON, Canada
  • 9.  RE: Solution file problem with Chrome 72
    Posted 4 days ago
    Thanks for this information Jesse.  We were encountering something similar with CRM Excel exports today (getting files with the name .xslx' ) and this appears to be the cause.
    Leif Farney
    United States Olympic Committee
    Colorado Springs CO
