On-demand workflows and Version 9.1
  • 1.  On-demand workflows and Version 9.1
    Posted Jan 10, 2019 12:24 PM
    We are supposed to move to Version 9 this weekend, but I am having trouble with the on-demand "clone opportunity" workflow on my Opportunity entity. My questions are 1. can you use on-demand workflows in Version 9.1? and 2. if you cannot use them, does anyone have a workaround for cloning an opportunity. I created this workflow so our sales team did not have to re-enter all of the opportunity information for an extension (for example). Any suggestions would be greatly appreciated.
    Mary Lauren
    Mary Lauren Hughes
    InfoWorks, Inc.
    Nashville, TN
  • 2.  RE: On-demand workflows and Version 9.1
    Posted Jan 10, 2019 12:46 PM
    Hi Mary,
    No issues running On-Demand workflows in versions 9.1 and above. Perhaps the On-Demand workflows you have rely on custom workflow steps that were created following code that is no longer supported in the new versions?
    Also, it could be that there are hard coded steps within the workflow referrencing records (GUIDs) that are non-existent on the destination environment.
    Gus Gonzalez
    CEO, Elev8 Solutions
  • 3.  RE: On-demand workflows and Version 9.1
    Posted Jan 11, 2019 10:00 AM
    ​I'm having the same issue in my UI 9.1, I have a very simple workflow that online triggers an e-mail for Leads, no code, I don't have the menu option to even select a Workflow:
    Linda Lockard
    Lumina Foods, LLC
    Nashville TN
  • 4.  RE: On-demand workflows and Version 9.1
    Posted Jan 11, 2019 11:07 AM
    Edited by Edrei Mpanduki Jan 11, 2019 01:24 PM
    Linda, your screenshot looks like it's the Unified client interface and I don't think Run Workflow is available yet in the Unified Client but the option is available in the Web(classsic) client in version 9.1
    Edrei Mpanduki
    CRM Technical Analyst
    Fender Musical Instruments Inc
    Scottsdale AZ
  • 5.  RE: On-demand workflows and Version 9.1
    Posted Jan 11, 2019 12:29 PM
    @Linda Lockard - The on-demand workflow is available, but you have to enable Flow to see the menu option as the "Run Workflow" options is under the "Flow" menu:
    The "Run Workflow" section will have your on-demand workflows listed.
    Aaron Back, MCP
  • 6.  RE: On-demand workflows and Version 9.1
    Posted Jan 11, 2019 01:00 PM
    @Aaron Back, MCSE, Thank you very much, I will try this.​
    Linda Lockard
    Lumina Foods, LLC
    Nashville TN
  • 7.  RE: On-demand workflows and Version 9.1
    Posted Jan 11, 2019 01:39 PM
    I didn't realize this, Thanks Aaron
    Edrei Mpanduki
    Scottsdale AZ
