Business Process Flow disappears (Project Services - Project)
  • 1.  Business Process Flow disappears (Project Services - Project)
    Posted 22 days ago
    Hi everyone,
    when I try to create a project the Standard Business Process Flow "Project Stages" shows up very shortly and then disappears. It does not appear again. I have tried to deactivate and activate the Process Flow, cleared my Cache & so on but nothing helped.
    This problem appeared right after I upgraded the Project Services part and also in a newly created Demo Environment.
    Has anyone experienced the same problems? Any suggestions what might solve it?
    Thanks in advance!
    Isabel
    Isabel Schauß
    Projectmanager and Consultant D365 CE
    Arineo GmbH
    Göttingen
  • 2.  RE: Business Process Flow disappears (Project Services - Project)
    Posted 20 days ago
    @Isabel Schauß I just saw the same thing happen in my different environments. I'll do some digging. ​
    Antti Pajunen
    Consultant, Dynamics 365 Customer Engagement
    Innofactor
  • 3.  RE: Business Process Flow disappears (Project Services - Project)
    Posted 20 days ago
    @Antti Pajunen: Perfect - thanks! I am curious what the solution might be!
    Isabel Schauß
    Arineo GmbH
    Göttingen
    Isabel Schauß
    Arineo GmbH
    Göttingen
  • 4.  RE: Business Process Flow disappears (Project Services - Project)
    The reply comes from the one and only Michael Nunes so quoting him:
    Hi a client I worked on recently had this issue and this was logged with Microsoft. A fix is to come out early in December as part of an update but you can fix it by disabling the event handler for collapseProcessControl on the Project form properties. Hope this helps :)
    Antti Pajunen
    Innofactor
  • 5.  RE: Business Process Flow disappears (Project Services - Project)
    Hi Antii,
    thanks for your Reply. The solution sounds perfect to me - especially because December is not far. I think I can wait for the update. I will probably try the Workaround on a Trial instance just out of curiosity. Thanks again!
    Isabel
    Isabel Schauß
    Arineo GmbH
    Göttingen
