Returnng to the Main Form of an an entity.
  • 1.  Returnng to the Main Form of an an entity.
    Posted Sep 16, 2019 08:58 AM
    ​I've created a new entity with multiple forms. I have also established relationships with other existing entities as well.
    As I click on a specific record displaying on the main form, it will navigate to another form to display relative data (which may be via an established relationship to another entity). As I click on an attribute or link on that form it will take me to a different form to display that relative data.
    Now I need to return to the first form, where I started my process on, to compare some information.
    Is there a configurable method of returning to the original form where I started my process on without having to start all over again or would this requiring coding  and some serious ingenuity??
    Jose Villa
    Business Analyst
    Blue Cross Blue Shield of Louisiana
    Baton Rouge LA
  • 2.  RE: Returnng to the Main Form of an an entity.
    Posted Sep 16, 2019 11:24 AM
    @Jose Villa - If the form of Entity B contains a lookup field linking the record to Entity A, then the lookup field can be clicked to return to Entity A.
    However, if you are defining a business process to assist users and navigate them from form to form, then I would suggest you use Business Process Flow. You can have the stages tied to the entities needed which will automatically switch the users from form to form. ​
    ACE Microtechnology
  • 3.  RE: Returnng to the Main Form of an an entity.
    Posted Sep 16, 2019 11:30 AM
    Thank you so much Aaron.  I believe your first option to be the simplest. Can't believe I didn't catch that!!!​
    Jose Villa
    Business Analyst
    Baton Rouge LA
  • 4.  RE: Returnng to the Main Form of an an entity.
    Posted Sep 16, 2019 04:09 PM
    @Jose Villa - Glad it helped! Would you be so kind to mark my response as the "Best Answer"? You can do this by clicking the down arrow next to the "Reply" button. ​
    ACE Microtechnology
