Can a BPF start with a condition?
  • 1.  Can a BPF start with a condition?
    We, unfortunately (I inherited this when I started), have a BPF whose first stage contains 15 fields.  There can be one of seven business rules that can be executed when the opportunity loads that will show and hide combinations of these fields based on different conditions.  I believe a BPF cannot start with a condition.  Does anyone have an idea on how to streamline this process?
    William Zukas
    Qosina Corp
    Ronkonkoma NY
  • 2.  RE: Can a BPF start with a condition?
    Correct, a BPF cannot start with a condition. I am not sure I can offer more options to streamline a process without understanding what you are trying to accomplish. Can you provide more details?
    BroadPoint, Inc., Bethesda MD
  • 3.  RE: Can a BPF start with a condition?
    Posted 9 days ago
    Hi @William Zukas,
    A BPF cannot start with a condition. But you can conditionally start or switch to another BPF. As @Nelson Johnson said, I would want to understand your business need before recommending this because there is usually a simpler way to get things done. BUT, if you'd like to try it, the process can be done with JavaScript, I believe the command will look something like this:
    if (formContext.getAttribute("name").getValue() == "BPF2" && formContext.data.process.getActiveProcess().getId().toUpperCase() != strGUIDofBPF2), formContext.data.process.setActiveProcess(strGUIDofBPF2);
    The above was me fat-fingering it. Check out this article for more info: https://community.dynamics.com/365/unified-interface/f/unified-interface-forum/376139/setactiveprocess-javascript-function-not-switching-enabled-business-process-flows-on-case-entity?pifragment-106147=1#responses
    Geoff Ables
    Managing Partner
    C5 Insight
    Charlotte NC
  • 4.  RE: Can a BPF start with a condition?
    Posted 7 days ago
    I'm not sure if this will help, but we have a scenario where it would be ideal if the BPF could start with a condition.  The way I handled it was to put a single field in the first stage - that field is the Opportunity type and that field is also the first required field on the form.  So, my BPF branches different ways depending on the opportunity type chosen.  When the user creates a new opportunity, the first thing they do is select the opportunity type on the form, which, in turn, completes that first stage of the BPF and the appropriate branch of the BPF instantly appears.  So the user is never actually interacting with that first stage of the opportunity - they finish filling in the f orm and then work their way through the rest of the stages.
  • 5.  RE: Can a BPF start with a condition?
    Posted 6 days ago
    Are all options possible for all users?
    IF not, you could potentially create streamlined BPFs for each version, and use security roles to determine which is used.
    Jamie Hirst
    https://thatqueer365guy.uk
    Functional Consultant
    Hirst Dynamics
    Stockport
  • 6.  RE: Can a BPF start with a condition?
    Posted 6 hours ago
    Hi Will,
    We could possibly have a field on the form and based on the field's value, we could render the BPF if showing/hiding the BPF is what you would want. But otherwise Jill's suggestion also works well, I think!!
    Bala S
    Balachandar Swaminathan
    San Jose
