Greetings,
It seems that with every week I find a change, that I have not created to our system.
This week my reports header ribbon changed.
Actually all entity(column) headers have changed, they are missing Run Report.
I no longer have the option to run reports from the reports entity or from an Opportunity or Lead entity.
You can see the reports when in reports, but when you click on the report nothing happens and there is no run report at the top header.
In the attached image, the ellipsis options but none that offer run report.
Can anyone explain what is happening?
Or more importantly how I can fix this. It seems that weekly now changes are occurring that are unexplainable.
I tried to get into the workbench to try to see what has happened there, but it kept timing out.
I haven't been in the workbench now for 6+ months.
I have not made changes to the system lately.
Other than having to export some of the Note reports to report builder to fix the HTML issues.
This is a simple export RDL correct the txt field and import.
It's all reports now.
The funnel that use to be available to go in the back so you could create a query is also missing from the top header.
Your assistance is much appreciated.
Chris.
Chris Adams
Nidec Motor Corporation
St Louis
