D365 forms
  • 1.  D365 forms
    Posted 27 days ago
    As we attempt to build out our first solution in D365 (latest version), I appear to have gotten stuck on forms... I created a new form, looks fine. I however can only find it when I open the legacy app. (That took a while to figure out as well...) In our on-prem version 8.5, I'd just add it to the app and make it the default - but here I can't even switch to it unless I go into Legacy. What am I missing so that this form is also available in the customer service hub? Thanks for any insights! :)
    Gretchen Garcia
    Systems Administrator
    Denver Public Library
    Denver CO
  • 2.  RE: D365 forms
    Posted 26 days ago
    Gretchen -
    The 2 things that need to happen to view a form in the unified interface are to make sure the form is checked in the app designer and make sure you have enabled appropriate security roles on the form....and that you are checking for the form with an appropriate security role.
    Hope this helps!
    -Jill
  • 3.  RE: D365 forms
    Posted 26 days ago
    Jill adding it to the app was it. We've done apps before in 8.5 but I didn't realize that's what that opening screen of all the tiles are. Thank you! Man this interface is so different. It's going to take us a while to figure it all out.
    Gretchen Garcia
    Denver CO
