I'm implementing this capability into something I'm doing for the first time. I just ran into the same issue. What worked for me was not including key fields in the update. It defeats the purpose of the Upsert because I have to distinguish between a create, where I include the fields used in the key, and the update where I exclude them. I haven't done exhaustive testing to validate my presumptive findings but it may help if someone finds themselves stuck.
Update: I probably should read docs more closely. Never include the fields used as part of a key in the upsert. Just specify them or it in the key collection or as a single key in the Entity constructor. That will place the key values in the correct fields on create and won't try to update them on the update.
Ben Sexton
Cornerstone Advisors, Inc.
Sent: Sep 18, 2019 11:38 AM
Subject: UpsertRequest Failing WIth Alternate Key
Thanks for your response. I have verified the KeyAttributeCollection has the attributes populated from the Alternate Key. Also, this entity has two (2) Alternate Keys. Does this present a problem for UpsertRequest?
// Create an ExecuteMultipleRequest object.
var requestWithResults = new ExecuteMultipleRequest() {
// Assign settings that define execution behavior: continue on error,
// return responses.
Settings = new ExecuteMultipleSettings() {
ContinueOnError = false,
ReturnResponses = true
// Create an empty organization request collection.
Requests = new OrganizationRequestCollection()
// Add a UpsertRequest for each entity to the request collection.
foreach( var entity in eCollection.Entities ) {
KeyAttributeCollection altKey = new KeyAttributeCollection();
altKey.Add( "l3t_line_number", entity[ "l3t_line_number" ] );
altKey.Add( "l3t_squadron_id",
entity.GetAttributeValue<EntityReference>( "l3t_org_squadron" )
.Id.ToString() );
altKey.Add( "l3t_takeoff_time_est_text",
entity.GetAttributeValue<DateTime>( "l3t_takeoff_time" )
.ToString() );
Entity newEnt = new Entity( "l3t_flights", altKey );
// Required fields
newEnt[ "l3t_program_site" ] =
entity.GetAttributeValue<EntityReference>( "l3t_program_site" );
newEnt[ "l3t_flightdate" ] =
entity.GetAttributeValue<DateTime>( "l3t_flightdate" );
newEnt[ "l3t_entry_type" ] =
entity.GetAttributeValue<OptionSetValue>( "l3t_entry_type" );
newEnt[ "l3t_addreason" ] = new OptionSetValue(
( int )AddReasonCode.AddReason.SCHEDULED );
newEnt[ "l3t_org_squadron" ] =
entity.GetAttributeValue<EntityReference>( "l3t_org_squadron" );
newEnt[ "l3t_document_number" ] =
entity.GetAttributeValue<string>( "l3t_document_number" );
UpsertRequest request = new UpsertRequest { Target = newEnt };
requestWithResults.Requests.Add( request );
} // foreach
Log.Debug( "Waiting for response..." );
// Display the results returned in the responses.
// Limit is 1000 or Throttle on BatchSize greater than 1000...
var responseWithResults =
( ExecuteMultipleResponse )_service.Execute( requestWithResults );
if( responseWithResults.IsFaulted ) {
var faultMsg = string.Empty;
for( int i = 0; i <= responseWithResults.Responses.Count; i++ ) {
faultMsg += i + ". " +
responseWithResults.Responses[ i ].Fault.Message + "\n";
} // foreach
Log.Error( faultMsg );
throw new Exception( faultMsg );
} // if} // if
Rodrick Hales
Vertex Aerospace
Madison
Sent: Sep 18, 2019 09:13 AM
Have you checked that you're using the Attribute and not the key for your alternate key? (https://community.dynamics.com/crm/b/mscrmcustomization/posts/upsert-request-using-alternative-key) Might help to show your code.
Daryl LaBar
President, MVP
Gap Integrity
Fishers IN
Sent: Sep 17, 2019 11:47 PM
The UpsertRequest from the Dynamics CRM SDK is failing with Alternate Key. I keep getting the following error message when I need to Update:
A record that has the attribute values [MY_ALT_KEY_ATTRIBUTES] already exists. The entity key [MY_ALT_KEY_NAME] requires that this set of attributes contains unique values. Select unique values and try again.
The create part of the UpsertRequest works very well. This only happens when I hope for the update.
Why would I get the error above ONLY when the update part is triggered?
I have tried this with Duplicate Detection for my entity turn off and still the same results.
Using Dynamics 365 v9.0, GCC tenant. Any suggestions would be greatly appreciated.
Rodrick Hales
Vertex Aerospace
