UpsertRequest Failing WIth Alternate Key
  • 1.  UpsertRequest Failing WIth Alternate Key
    Posted Sep 17, 2019 11:48 PM
    Edited by Rodrick Hales Sep 17, 2019 11:55 PM
    The UpsertRequest from the Dynamics CRM SDK is failing with Alternate Key. I keep getting the following error message when I need to Update:
    A record that has the attribute values [MY_ALT_KEY_ATTRIBUTES] already exists. The entity key [MY_ALT_KEY_NAME] requires that this set of attributes contains unique values. Select unique values and try again.
    The create part of the UpsertRequest works very well. This only happens when I hope for the update.
    Why would I get the error above ONLY when the update part is triggered?
    I have tried this with Duplicate Detection for my entity turn off and still the same results.
    Using Dynamics 365 v9.0, GCC tenant. Any suggestions would be greatly appreciated.
    Rodrick Hales
    Vertex Aerospace
  • 2.  RE: UpsertRequest Failing WIth Alternate Key
    Posted Sep 18, 2019 09:14 AM
    Have you checked that you're using the Attribute and not the key for your alternate key? (https://community.dynamics.com/crm/b/mscrmcustomization/posts/upsert-request-using-alternative-key)  Might help to show your code.
    Daryl LaBar
    President, MVP
    Gap Integrity
    Fishers IN
  • 3.  RE: UpsertRequest Failing WIth Alternate Key
    Posted Sep 18, 2019 11:38 AM
    Edited by Rodrick Hales Sep 18, 2019 12:36 PM
    Thanks for your response. I have verified the KeyAttributeCollection has the attributes populated from the Alternate Key. Also, this entity has two (2) Alternate Keys. Does this present a problem for UpsertRequest?
    // Create an ExecuteMultipleRequest object.
    var requestWithResults = new ExecuteMultipleRequest() {
    // Assign settings that define execution behavior: continue on error,
    // return responses.
    Settings = new ExecuteMultipleSettings() {
    ContinueOnError = false,
    ReturnResponses = true
    // Create an empty organization request collection.
    Requests = new OrganizationRequestCollection()
    // Add a UpsertRequest for each entity to the request collection.
    foreach( var entity in eCollection.Entities ) {
    KeyAttributeCollection altKey = new KeyAttributeCollection();
    altKey.Add( "l3t_line_number", entity[ "l3t_line_number" ] );
    altKey.Add( "l3t_squadron_id",
    entity.GetAttributeValue<EntityReference>( "l3t_org_squadron" )
    .Id.ToString() );
    altKey.Add( "l3t_takeoff_time_est_text",
    entity.GetAttributeValue<DateTime>( "l3t_takeoff_time" )
    .ToString() );
    Entity newEnt = new Entity( "l3t_flights", altKey );
    // Required fields
    newEnt[ "l3t_program_site" ] =
    entity.GetAttributeValue<EntityReference>( "l3t_program_site" );
    newEnt[ "l3t_flightdate" ] =
    entity.GetAttributeValue<DateTime>( "l3t_flightdate" );
    newEnt[ "l3t_entry_type" ] =
    entity.GetAttributeValue<OptionSetValue>( "l3t_entry_type" );
    newEnt[ "l3t_addreason" ] = new OptionSetValue(
    ( int )AddReasonCode.AddReason.SCHEDULED );
    newEnt[ "l3t_org_squadron" ] =
    entity.GetAttributeValue<EntityReference>( "l3t_org_squadron" );
    newEnt[ "l3t_document_number" ] =
    entity.GetAttributeValue<string>( "l3t_document_number" );
    UpsertRequest request = new UpsertRequest { Target = newEnt };
    requestWithResults.Requests.Add( request );
    } // foreach
    Log.Debug( "Waiting for response..." );
    // Display the results returned in the responses.
    // Limit is 1000 or Throttle on BatchSize greater than 1000...
    var responseWithResults =
    ( ExecuteMultipleResponse )_service.Execute( requestWithResults );
    if( responseWithResults.IsFaulted ) {
    var faultMsg = string.Empty;
    for( int i = 0; i <= responseWithResults.Responses.Count; i++ ) {
    faultMsg += i + ". " +
    responseWithResults.Responses[ i ].Fault.Message + "\n";
    } // foreach
    Log.Error( faultMsg );
    throw new Exception( faultMsg );
    } // if} // if
    Rodrick Hales
    Vertex Aerospace
    Madison
