Opportunity forecasting with multiple unit groups
  • 1.  Opportunity forecasting with multiple unit groups
    Posted Aug 26, 2018 09:24 AM
    Hello there,
    Our different unit groups assigned to our products are based on our GL account structure and financial reporting.  When we have multiple unit groups being sold on one opportunity we can't find a way to forecast appropriately.  There seems to be a disconnect between the opportunity lines, which contains the until group, and the opportunity where all other needed information is held.
    Has anyone had similar and figured this out?  Or found other ways to forecast by product groups to match your financials?
    Thank you.
    Tammie Viot
    Business Architect
    Command Alkon Incorporated
    Birmingham AL
  • 2.  RE: Opportunity forecasting with multiple unit groups
    Posted Aug 27, 2018 04:11 PM
    We utilize Item Group which relates back to the GL's that are specified. I believe it all configuration and out of the box. Although we are still on Dynamics AX 2012 I believe this portion carried over to 365.
    Michael Foss
    Functional/Business Systems Analyst
    Lifetime Products, Inc.
    Clearfield UT
  • 3.  RE: Opportunity forecasting with multiple unit groups
    Posted Aug 30, 2018 03:30 AM
    What reporting tool are you using?
    Have you tried using PowerBI? Although not sure about your structure i would geuss that you can get the connect working using PowerBI using custom columns.
    all the best, Michael
    Michael Dohr
    COO
    mscrm-addons.com
