Portal - To read json using LIQUID
  • 1.  Portal - To read json using LIQUID
    I am doing a Fetch XML on the portal page using LIQUID, and receiving a json output on the same page as a result.
    I need to read this json instantly when I receive it and do certain things on the html.
    For example:
    "TrustId": "32E18BFF-6795-EA11-A811-000D3A4A17C4",
    "schools": [
         {      "guid": "52G18FFF-3795-FA11-N811-000E3A4A17C5",
                "name": "abc school",
                 "Area": 2
         {       "guid": "62G18FFF-3795-FA11-N811-000E3A4A17C5",
                "name": "def school",
                 "Area": 3
    I know we can make our web page as JSON mime type and can get it using jquery or javascript from the URL.
    But can this be done directly on a page to access JSON object as mentioned in example above?
    Kind regards,
    Jimmy mcad
  • 2.  RE: Portal - To read json using LIQUID
    Is there a reason why you can't just use the Liquid capability to loop through the records returned by the FetchXML?  Check this blog post for an example:
    http://dyn365apps.com/2017/09/14/dynamics-365-portals-liquid-templates-part-3-retrieve-data-using-fetchxml/
    The relevant code is this part:
    {% for result in my_query.results.entities %}
          <div name="content" style="padding: 15px 30px 0 0; clear: both;">
            <h2> {{ result.fullname | escape }} </h2>
          	<div name="image" style="width: 300px; float: left; padding: 0 0 0 15px;">
          	  <img src={{ result.websiteurl | escape }} height="150" width="150"  >
          	</div>
          	<div name="main-content" style="margin-left: 300px; max-width: 800px;">
          		<p> {{ result.description | escape }} </p>
          		<br />
          	</div>
          	<div class="clear"></div>
          </div>
      {% endfor %}​
    Chris Harrington
    Solutions Architect
    PowerObjects, an HCL Company
