CRM 365 Portal - Related records in lookup not appearing
  • 1.  CRM 365 Portal - Related records in lookup not appearing
    Posted May 30, 2019 02:17 PM
    I need help in getting list of related records in lookup field in Customer service portal.
    Expected result = lookup field should display account list where customer (account) of case is parent account.
    In CRM, I have already added lookup field in web - create case form and applied related record setting too. I can see expected data in lookup.
    In Portal, I can see lookup field but no data is appearing in it. I have tried adding Entity Form Metadata and the relationship in it but still no luck.
    It will be helpful if anyone can point out what is missing or have any alternate solution.
    Neha Marwaha
    Programmer Analyst
    Cineplex Inc.
    Toronto ON
  • 2.  RE: CRM 365 Portal - Related records in lookup not appearing
    Posted May 31, 2019 07:54 AM
    Hi Neha
    In my experience, in most cases where data doesn't appear on the portal has to do with entity permissions.  Ensure that you have these properly configured and the account data will likely appear:
    https://docs.microsoft.com/en-us/dynamics365/customer-engagement/portals/assign-entity-permissions
    HTH
    Cheers
    Nick
    Nick Doelman
    Microsoft MVP
    Ottawa ON
  • 3.  RE: CRM 365 Portal - Related records in lookup not appearing
    Posted May 31, 2019 08:27 AM
    Agree with Nick here, typically this is an entity permission issue. Check if you have setup an Entity Permission for the Account entity, and it will most likely need read, append, and append to.
    Good luck!
    Chris Harrington
    Solutions Architect
    PowerObjects, an HCL Company
  • 4.  RE: CRM 365 Portal - Related records in lookup not appearing
    Posted Jun 14, 2019 11:03 AM
    Thanks Nick & Chris,
    Lookup is working after creating correct Entity permission.
    Neha Marwaha
    Programmer Analyst
    Cineplex Inc.
    Toronto ON
