Get all emails, phone calls, appointments for contacts on account custom entity
  • 1.  Get all emails, phone calls, appointments for contacts on account custom entity
    Posted Mar 15, 2019 01:22 PM
    I am looking for some feedback on how to proceed with this problem.
    Scenario: I have a custom entity with an N:N relationship for accounts. I also have connections to this entity for contacts of different roles. Ex. "John Doe" as "Stakeholder". I would like to run a report or query that pulls all emails, phone calls, and appointments for all contacts who are in the accounts associated with the custom entity record.
    I attempted this using FetchXML, but there are too many levels for this to be effective. I can only pull the data using XrmToolBox, and I am not able to make this available to each user.
    What is a sustainable approach to this need?
    Example of the FetchXML code (works in XrmToolBox only).
    <fetch version="1.0" output-format="xml-platform" mapping="logical" distinct="true" >
      <entity name="activitypointer" >
        <attribute name="activitytypecode" />
        <attribute name="subject" />
        <attribute name="statecode" />
        <attribute name="prioritycode" />
        <attribute name="modifiedon" />
        <attribute name="activityid" />
        <attribute name="description" />
        <attribute name="ownerid" />
        <attribute name="senton" />
        <attribute name="allparties" />
        <order attribute="modifiedon" descending="false" />
        <filter type="and" >
          <condition attribute="statecode" operator="eq" value="1" />
          <condition attribute="activitytypecode" operator="in" >
            <value>4202</value>
            <value>4210</value>
            <value>4201</value>
          </condition>
          <filter type="or" >
            <condition attribute="regardingobjectid" operator="eq" uiname="Record ABC" uitype="new_linked" value="{AAAAAAAA-AAAA-AAAA-AAAA-AAAAAAAAAAAA}" />
            <condition entityname="opp" attribute="new_linked" operator="eq" uiname="Record ABC" uitype="new_entity" value="{AAAAAAAA-AAAA-AAAA-AAAA-AAAAAAAAAAAA}" />
            <condition entityname="customentity" attribute="new_linked" operator="eq" uiname="Record ABC" uitype="new_entity" value="{AAAAAAAA-AAAA-AAAA-AAAA-AAAAAAAAAAAA}" />
          </filter>
        </filter>
        <link-entity name="opportunity" from="opportunityid" to="regardingobjectid" link-type="outer" alias="opp" />
        <link-entity name="customentity" link-type="outer" alias="customentity" />
      </entity>
    </fetch>
    Adam Posegate
    Fox Valley Technical College
    Appleton WI
  • 2.  RE: Get all emails, phone calls, appointments for contacts on account custom entity
    Posted Mar 16, 2019 12:39 PM
    Adam,
        The word 'sustainable' can be interpreted different ways. Are you asking for a way to do it without custom code, such as JavaScript? How about third party products?
    Frankly, the N:N relation does not give you many options to present the data you demonstrated above. I am not clear on the particular use-case so I cannot offer an implementation suggestion. Based on your specific query above, I think your best option is to use JavaScript to modify a subgrid on an entity form, using the FetchXML you developed. There are a number of blog articles that show you how to do it. Here are a couple:
    CRM 2015 (Update 1) filter a sub grid to show data based on hierarchy using FetchXML
    From <http://mehmet.ozdemir.id.au/2015/03/crm-2015-filter-a-sub-grid-to-show-data-based-on-hierarchy-using-fetchxml/>
    Dynamically Change Sub-Grid fetchXML with a Small Twist (Fix)
    From <http://blog.navantis.com/dynamically-change-sub-grid-fetchxml-with-a-small-twist-fix/>
    BroadPoint, Inc., Bethesda MD
  • 3.  RE: Get all emails, phone calls, appointments for contacts on account custom entity
    Posted Mar 18, 2019 09:37 AM
    Sustainable, in my case, means not having to manually run this query through XrmToolBox each time.
    The cliff I encounter with filtering the subgrid data (link 1) is that the method is no longer supported. I will look further into the second link. It has some potential for this effort.
    Adam Posegate
    Appleton WI
