Data Export Service
  • 1.  Data Export Service
    Posted Jul 05, 2020 05:35 PM
    Hi all
    Slightly strange question that I hope someone may be able to help with.
    Recently we have noticed a significant degradation of service when running SQL queries against our Azure DB holding CRM data from the export service.  Looking at the system usage, we can see a number of queries that appear to be making the DB run at 100% available resources.  These appear to be merge queries for certain entities.  Does anyone here know whether this is normal?
    Your responses gratefully received!
    Regards
    Matt
    Matthew Vizor
    Shelter
  • 2.  RE: Data Export Service
    Posted 25 days ago
    If it's just an Azure DB, can you scale it up to handle better if you're seeing performance issues?
    Further more, have you seen the TSQL endpoint that is on the verge of launching? That may make your issue redundant!
    Matt Beard
    Senior Software Engineer
    Data8
