Bulk Edit
  • 1.  Bulk Edit
    Posted 22 days ago
    When using built in bulk editing tool, upon saving, check boxes are being set to their default values even though they were not updated to do so. Has anyone experienced this before? Is there a fix to this?
    Carter Yarnell
    Product Manager
    Conference Technologies, Inc.
    Maryland Heights MO
  • 2.  RE: Bulk Edit
    Posted 22 days ago
    What entities are you seeing this occur in?
    Mary Cunningham
    Director – Service Technology
    Comfort Systems USA
    (561) 310-2134
    BE SAFE  I  BE HONEST  I  BE RESPECTFUL  I  BE INNOVATIVE  I  BE COLLABORATIVE
  • 3.  RE: Bulk Edit
    Posted 22 days ago
    We are seeing this on the opportunity entity, when bulk editing the quote entity associated with the opportunity.
    Carter Yarnell
    DevOps Coordinator
    Maryland Heights MO
  • 4.  RE: Bulk Edit
    Posted 22 days ago
    Did you check to make sure any workflows, business rules, or plugins are not to blame?
    Are you using the Unified Interface or Web Classic? On-prem or on-line?
    If you are using Unified Interface, did you replace the OOTB Yes/No with the Checkbox control? if yes, then it sounds like a bug you need to report to MS.
    BroadPoint, Inc., Bethesda MD
  • 5.  RE: Bulk Edit
    Posted 22 days ago
    We are indeed using Unified Interface, and we have in fact replaced Yes/No with the Check box control
    Carter Yarnell
    DevOps Coordinator
    Maryland Heights MO
  • 6.  RE: Bulk Edit
    Posted 22 days ago
    Carter, do you have audit logs turned on?  If there are workflows being triggered you will have multiple entries in the audit logs with the same time stamp showing what fields were changed.
    Jonathan Blackham
    Sales Operations Specialist
    Valin Corporation
