can XRMTool box be used for this scenario- need help!
  • 1.  can XRMTool box be used for this scenario- need help!
    Posted Nov 12, 2019 09:02 AM
    I know XRM Toolbox can be used to auto generate #s but I have a user who needs the following to generate (transferring his stuff from TrackOps to CRM) so his standard projects pull in like this ex: B1903477EP . the B stands for Brazil. the 190 stands for the year the other 4 numbers would need to generate in chronological order, and the EP would also change based on the type of job performed. so it could be EP, SD, TR, IN, CO, GP, SA... there are about 10 or so options.
    Is this possible to generate something based on pulling in the field type? ​I've only had to use XRM toolbox to autogenerate project numbers but it was a simple formula of XXX-1234 this situation has many moving parts.
    thanks!
    Heather L
  • 2.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 12, 2019 09:07 AM
    My approach would be to set up individual fields for each of those items, (including the sequential numbers), then use a workflow to concatenate all the elements into a single field.
    BroadPoint, Inc., Bethesda MD
  • 3.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 12, 2019 09:12 AM
    that sounds complicated! :)
    Currently, I set up the case type (the EP, SA, GP etc) as a drop down box. so that wouldn't work if I tried your route then?
    Heather L
  • 4.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 13, 2019 04:18 AM
    Hi Heather,
    The route Nelson suggested will works if you get the label of the option set you want. If I'm not wrong, the drop down you created for EP, SA and GP are multiple option set. These option set has values and labels. When you try to read the value it will get OptionSetValue. you can use Custom workflow/JavaScript  to concatenate and update the field based on your need. All you need to do is get option set label based on option set value and concatenate it.
    Ram Kiran Yarramasu
    Aha Apps
    Glen Allen VA
  • 5.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 13, 2019 09:55 AM
    Yes, it would work easily. here is what you should do
    • Create a field for the Year+sequential ID using XRMtoolbox to generate the numbers, for example using this as the format: {DATETIMEUTC:yy}0{SEQNUM:4} will generate the type of number you requested above such as "1901234" - see https://jonasr.app/2017/10/anm/ for details
    • setup a field for the country (your example was B for Brazil) which could be an option set or text field
    • you already have a regular option set for type of job performed
    • create a workflow to trigger when the sequential ID field (you created above) is modified
      • update record
        • in the Name field, you can insert all 3 of the above fields in the order you want {country}{number}{job type}
    Does that help?
  • 6.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 13, 2019 10:52 AM
    Thanks @Nelson Johnson I sent you a PM. I will try to figure this out with your advice above!
    Heather L
  • 7.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 12, 2019 10:39 AM
    Heather
    This is a simple js code that "sorta" meets the requirements. It is unique by the second. You can then attach this code whenever the country or job gets change and update the "auto generated" field.
    const autoGenerate = (country, year, job) => {
      const startDate = new Date(year, 0, 1),
            diffDate =  Math.round((Date.now() - startDate) / 1000);
      return `${country.substring(0,1)}${diffDate}${job}`
    Rex Kenley Tan, MCSA, MCSD
    Tallmadge OH
  • 8.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 13, 2019 02:25 AM
    Hi @Heather Laughlin
    The Auto Number Manager tool in XrmToolBox cannot compose this type of complex numbers. Or more correctly - the Auto Number feature in the CDS platform does not support it, and my tool only does what the platform supports.
    You can read more about the tool and its capabilities here: https://jonasr.app/tag/ANM/
    My guess is third party offers like North52 can accomplish what you are looking for.
    The idea from @Nelson Johnson is also viable if you don't want to write code for it.
    Jonas
    Jonas Rapp
    MVP
    Sweden
  • 9.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 13, 2019 08:52 AM
    @Jonas Thank you!! I was under the impression his request was a little too far out of the box for that to work, but glad you confirmed it. As far as the other options above - will those ideas still work?
    I need to have this completed by next week so trying to figure out my best option to move forward. I have no experience with programming or java script so I really want to understand the best way to move forward if possible.
    Heather L
  • 10.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 13, 2019 01:38 PM
    ok in reading I see that Multi Option set cannot be used in a workflow? Am I misunderstanding? I am fine with using regular option set if needed- just want to make sure before I set it up incorrectly. This field will be pulled in for a workflow and to use as part of a # that needs to be autogenerated based on the service provided. But they can only select 1 service at a time.
    Heather L
  • 11.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 13, 2019 10:56 PM
    You are right that multi-select option sets cannot be used in an update step, and I think you will be better off using a regular option set, based on what you explained in your original question. The reason I say that is because if you use a multi-select option set, and the user selects all options, I suspect that you would not want the number generated to be B1903477EPSDTRINCOGPSA, correct?
  • 12.  RE: can XRMTool box be used for this scenario- need help!
    Posted Nov 14, 2019 08:50 AM
    Thanks for clarifying! Yes, I am going to stick with the original option set. I appreciate everyone's help! Although, the multi options set does look cool, its disappointing you can't use it in workflows so it hinders so much of its ability to be used!
    Heather L
