CRM Export Dynamic Worksheet
  • 1.  CRM Export Dynamic Worksheet
    I'm hoping someone who has dynamic worksheets working with CRM online v9 can assist. I'm wanting to be able to go via CRM and export the dynamic worksheets and simply refresh from excel. However when I do this and try to refresh, I get the bellow error of "This Web query returned no data. etc..". Upon more reading I found I had to install the Dynamics 365 add in from App Source. However when I did this, it prompts me for the server URL. I've entered our usual URL that we use to access Dynamics 365 online but it returns the error "Failed to retrieve the server config".
    I'm not sure if I've missed one of the basic steps to make this work but I'd love to hear from anyone that has this operating to let me know if this might be the case.
    Thanks in advance
    Daniel Demers
    Richard Jay Laundry
  • 2.  RE: CRM Export Dynamic Worksheet
    I'm going to miss this too when our own CRM moves to online.  The data refresh from a Dynamic worksheet on CRM Online is meant to work only if you still have the old style CRM Client for Outlook installed, without that it wont work.  The new version is to use an Excel Template, these are also a great feature.
    Andrew Wolfe
    Head of CRM Practice
    Technology Services Group
    United Kingdom
  • 3.  RE: CRM Export Dynamic Worksheet
    Hi @Daniel Demers  You could try to use the Open in Excel Online.  From here you are able to edit the data and send it back to Dynamics similar to how the Dynamic worksheet worked.  I've had no issues using this so far.  Also I've exported as a Static worksheet and then simply re-imported the sheet through the Data Import.  ​
    Eric Veneziano
    Sales System Analyst
    Minitab, Inc.
    State College PA
  • 4.  RE: CRM Export Dynamic Worksheet
    Thanks for your suggestion Eric. However when I export to a Dynamic Worksheet and open with excel online, I still get the error that the data cannot be refreshed. Would you be able to outline the steps you follow to get this to work please? The steps I've followed are
    1- Export to Dynamic Worksheet
    2- Upoload this file to one drive
    3- Open this file with Excel online
    4- Click Refresh
    From the moment I open the file I get the below error mentioning the unsupported features. I'll be very interested to know how you have managed to get this to work. Thank you
    Daniel Demers
    Richard Jay Laundry
  • 5.  RE: CRM Export Dynamic Worksheet
    Hi Daniel
    To open in Excel online, choose the option in the command bar at the top. Go to your view or advanced find, then choose Export to Excel and Open in Excel online.
    This will then open Excel online inside of Dynamics and you can edit the data and save back to dynamics quickly.
    Hope this helps.
    Matt
    Matt Collins
    CRM/D365 Consultant
    Newcastle upon Tyne
  • 6.  RE: CRM Export Dynamic Worksheet
    Hi Matt,
    Yes this will open excel online, however it is not creating a dynamic worksheet. What I'm trying to figure out is how to create a dynamic worksheet from CRM which then allows refreshing of the data from excel. I was always able to do this easily with on-premise but have not yet had any luck with CRM online.
    Daniel Demers
    Richard Jay Laundry
  • 7.  RE: CRM Export Dynamic Worksheet
    Hi Daniel
    Apologies, i was only explaining how to get the Excel online functionality to work. You can't create a Dynamics worksheet with Excel online, but you can look at your data live from D365 in Excel online and it allow you to update/edit etc.
    If you want to use the Dynamics worksheet functionality, you should still be able to provided you have the CRM for Outlook plugin installed, not the light weight app, as Andrew suggested in his post. Are you saying you have this installed and you are getting these errors? Have you tried uninstalling and re-installing the plugin, removing all registry entries?
    thanks
    Matt
    Matt Collins
    CRM/D365 Consultant
    Newcastle upon Tyne
  • 8.  RE: CRM Export Dynamic Worksheet
    Have you tried manually creating the connection from Excel (instructions in the link below) instead of exporting from Dynamics?
    https://community.dynamics.com/crm/b/passiondynamics/archive/2018/07/16/connect-to-dynamics-crm-365-online-from-excel-reporting
    Ben Edgren
    CRM Applications Manager
    Hufcor, Inc
    Janesville WI
  • 9.  RE: CRM Export Dynamic Worksheet
    Hi Ben, yes that works no problem. However it's not what I'm trying to achieve. I'm trying to get the Dynamic Worksheet functionality up and running. It worked wonderfully when I used to have CRM on prem, but I've not been able to get it to work since being with D365 online. I've had some people say it can't be done with online and others that have said it should work. I'm hoping that someone on this forum will have first hand experience getting this functionality to work with D365 online and let me know what steps I might be missing.
    It's extremely useful for users to be able to export a given view from CRM which they then routinely format so that they only have to click the refresh button instead of formatting each time or using macros to achieve.
    Daniel Demers
    Richard Jay Laundry
