Hi All,
I trying to push my pcf control to my crm. when i use " pac pcf push --publisher-prefix contoso"
this terminal command does not push the custom control to my form. i do not see custom control on the form.
I am also getting error at the command terminal
"Error: Building temporary solution wrapper: failed. See obj\build.log for more details."
when i look into the log it says
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\Microsoft.Common.CurrentVersion.targets(816,5): error : The BaseOutputPath/OutputPath property is not set for project 'PowerAppsTools_contoso.cdsproj'. Please check to make sure that you have specified a valid combination of Configuration and Platform for this project. Configuration='Debug' Platform='HPD'. You may be seeing this message because you are trying to build a project without a solution file, and have specified a non-default Configuration or Platform that doesn't exist for this project. [c:\Users\Family\Documents\pcfTimeLineControl\src\obj\PowerAppsTools_contoso\PowerAppsTools_contoso.cdsproj]".
Anybody faced similar issue and also solved issue
Jeebo Mathews
Agricorp
