Dynamics Marketing Form Field Contact Mapping to Company Name
  • 1.  Dynamics Marketing Form Field Contact Mapping to Company Name
    Posted Feb 07, 2020 02:07 PM
    Hey there,
    We've been trying to set up a new form field in Marketing for Dynamics. We're setting up the Company Name field but are unable to select "company Name" from the "Contact mapping" drop down. It is, however, available in the "Lead mapping" drop down. We've not run into any other problems like this in any other form field. It seems that only when trying to select "Company Name" is when the issue occurs. Any thoughts on how we can get Company Name into the Contact mapping field or why it's not showing up?
    Bryan Wood
    Cherry Bekaert LLP
    Richmond VA
  • 2.  RE: Dynamics Marketing Form Field Contact Mapping to Company Name
    Posted Feb 10, 2020 11:54 AM
    Hi Bryan,
    Depends on how your system is set up, but on a Contact record the Company Name field is a lookup (Customer) but on a Lead record the Company Name field is a single line of text.  I believe that could be causing the issue  You may want to reuse or create another field on the Contact record to save that company name from the marketing form, and then use a workflow or something else to set the lookup field.
    Ben Edgren
    CRM Applications Manager
    Hufcor, Inc
    Janesville WI
  • 3.  RE: Dynamics Marketing Form Field Contact Mapping to Company Name
    Posted Feb 10, 2020 01:11 PM
    Thanks, Ben. We had suspicions it was due to the Customer type. Were hoping for other validation, but it looks like a workaround is in order.
    Bryan Wood
    Cherry Bekaert LLP
    Richmond VA
  • 4.  RE: Dynamics Marketing Form Field Contact Mapping to Company Name
    Posted Feb 12, 2020 07:11 PM
    Hello Bryan,
    Ben is correct, you cannot map a text field to a lookup.
    * Anyone that is not in the system you can add them as a lead and through qualification you can go through a matching process if that Account is already in the system and if not create a new account. This does require some manual checks but there are ways this can be automated.
    * Anyone that is already in the system will already have the account populated on the contact therefore there is no matching needed.
    Lauren Haapakoski
    CRM & Marketing Automation Consultant
    Wipfli
  • 5.  RE: Dynamics Marketing Form Field Contact Mapping to Company Name
    Posted Jul 01, 2020 04:57 PM
    Hi Bryan,
    Good question - we receive lots of questions around contact mapping - and just as important, contact attribute mapping for accurate dynamic and personalized communications.
    We actually worked with Wipfli here who also commented and spoke with Ben - both very well-versed.
    Give us a shout if you find you need more in-depth support.
    Happy to chat.
    Brooke Daniel
    bdaniel@coffee-dunn.com
    Brooke Daniel
    Coffee + Dunn
    McKinney TX
