CRM 365 Online Plugin and Azure Event Grid
  • 1.  CRM 365 Online Plugin and Azure Event Grid
    Posted 18 days ago
    I am testing a plugin to post on the event grid for the create and update events of different entities. In the implementation I use httpclient for the post and serialization with System.Runtime.Serialization.Json to avoid merge of assemblies.
    I was wondering if anyone has done this to anticipate possible performance problems.
    Silvio Souza
  • 2.  RE: CRM 365 Online Plugin and Azure Event Grid
    I can't answer your question but I will be starting my own implementation today so I'll be following this thread.  I had planned on adding the event grid assemblies and merging though.
    Ben Sexton
    Cornerstone Advisors, Inc.
  • 3.  RE: CRM 365 Online Plugin and Azure Event Grid
    Edited by Silvio Jose de Souza 17 days ago
    Here is my code.
    https://github.com/souzasilvio/EventGridPlugin
    Silvio Souza
  • 4.  RE: CRM 365 Online Plugin and Azure Event Grid
    This sounds interesting. Can you please share what possible benefits you could achieve by using Event Grid with CRM? Thanks :)
    Hasan Bazerbashi
    Sr. CRM/.NET Developer
    Cineplex Inc.
    Toronto ON
  • 5.  RE: CRM 365 Online Plugin and Azure Event Grid
    We'll be using it for integration triggers and in lieu of a traditional message bus.  Logic apps and serverless functions will consume the events and perform the integrations.  Event grid payload size limit has recently been increased to 1MB so it could also handle messages.
    Ben Sexton
  • 6.  RE: CRM 365 Online Plugin and Azure Event Grid
    Edited by Silvio Jose de Souza 13 days ago
    In our architecture, Event Grid is used to synchronize information between systems (CRM, ERP) and several micro services.
  • 7.  RE: CRM 365 Online Plugin and Azure Event Grid
    Not to sure about everything else you're doing, but your plugin base has committed the cardinal sin of sharing data at the class level.  This leads to race conditions.  If you grabbed the pluginbase from somewhere in the community, you need to ask them to fix it as well:
    https://www.youtube.com/watch?v=3sFSG0aYoR0
    Daryl LaBar
    President, MVP
    Gap Integrity
    Fishers IN
