Experiences with querying audit logs
  • 1.  Experiences with querying audit logs
    Posted May 07, 2019 10:32 AM
    Hi everyone,
    We were interested in learning about what sort of experiences you've had with with reporting on changes kept in the audit log. We've run into an issue where we need to identify contact records with data that changed in a certain field but are having a difficult time figuring out how to use the audit log to identify these en masse. Has anyone else had an experience like this? Have you been able to use SQL or another third party application to search audit logs?
    Matt
    Matthew Epstein
    Financial Services Institute
    Washington DC
  • 2.  RE: Experiences with querying audit logs
    Posted May 07, 2019 02:40 PM
    I have not had much luck using SQL, but have had luck using the XRMToolBox Audit History Extractor.
    Katie Warner
    Comagine Health
  • 3.  RE: Experiences with querying audit logs
    Posted May 09, 2019 10:08 AM
    We've used Kingswaysoft and it was ok, at least we found what we were looking for.
    https://community.dynamics.com/crm/b/sonomapartners/archive/2016/05/26/analyzing-audit-logs-using-kingswaysoft
    Kevin Harrington
    CRM Product Manager
    Universtiy College Cork
  • 4.  RE: Experiences with querying audit logs
    Posted May 10, 2019 02:02 PM
    Thank you both for these suggestions! We will look into these.
    Matthew Epstein
    Washington DC
  • 5.  RE: Experiences with querying audit logs
    Posted May 13, 2019 09:26 AM
    +1 for KingswaySoft.  We have had some audit log issues with a known Dynamics defect, but KingswaySoft is a great extraction tool to get them out for analysis/reporting.
    Kyle Buggie
    Columbus OH
  • 6.  RE: Experiences with querying audit logs
    Posted May 14, 2019 07:46 PM
    Agree with @Kyle Buggie, once you have the audit extracted out into a SQL server you could do various SQL queries to get the OLD Value / New Value of fields. However if you know of a specific set of records or you would like to see if there is pattern across a smaller subset of records than if you have a developer on site you could get someone to put together something like screen shot below
    Audit details for a field on a contact
    Abdul Majid
    Westwood Software Limited
  • 7.  RE: Experiences with querying audit logs
    Posted May 13, 2019 05:18 AM
    @Matthew Epstein
    Do you have a on-premise implementation with access to SQL Servers or is this Dynamics 365 online ?
    Abdul Majid
  • 8.  RE: Experiences with querying audit logs
    Posted May 15, 2019 03:54 PM
    Thank you both Kyle and Abdul, we will take a look at KingswaySoft, we are using Dynamics 365 online rather than on-premise.
    Matthew Epstein
    Washington DC
